iTunes and Airport Express
karthy
Oct 7, 2006
Hey,
I bought airport express, and after the frustration of learning that it doesn't work with Linksys, I've decided to keep it just to stream my music to my stereo. Is there a way to let iTunes stream to the Express while I am actually
connected to the internet with my Linksys? I can't stream unless my airport connection is also connected to the Express, not allowing my to get online.
Karthy
johalber
Oct 7, 2006
The Express needs a Router which supports WDS, depending on which Linksys you have you should be able to update the firmware to support WDS, this would enable your Linksys to run with the Express. I have a Linksys WRG54G and Express running perfectly for 2 years.
Johalber
