iTunes connection with a secured network couldn't be made
When I docked my iPhone today iTunes started up, but then I got a message something like "Your request for connecting to the iTunes store couldn't be completed because a connection with a secured network couldn't be made. Check if you have enabled SSL 3.0 use and TLS 1.0 use in your network settings on the configuration screen of internet".
I haven't changed anything in my settings since the last time I docked me phone and checked the settings and both ssl 3.0 and tls 1.0 are enabled..
Can anyone help me?
420greg
Jun 26, 2007
845
Orlando, Florida
What the f*ck!..
When I docked my iPhone today iTunes started up, but then I got a message something like "Your request for connecting to the iTunesstore couldn't be completed because a connection with a secured network couldn't be made. Check if you have enabled SSL 3.0 use and TLS 1.0 use in your network settings on the configuration screen of internet".
Can anyone help me?
Uncheck both boxes
Quit IE
Reopen IE
recheck them both
Quit Ie
Reopen IE
Try to connect to iTunes store.
A reboot would not hurt either.
