iTunes Coverflow problem
jay12
Oct 18, 2007
25
im having a small problem with an album i put on my phone.. when i load the playlist on to my phone it separates the tracks in to two albums.. same cover but three of the songs go under one cover and the rest go under the other cover.. i tried changing the tracklist order, making sure they all have the same artist name and album name and reuploading but its still splits in to two.. was wondering if anyone knew why.. thanks
kcarr91
Apr 14, 2007
62
this has happened to me what you have to do is check if they are spelled exactly the same
for example a space, period, or a capitol, it will start a new album
if you cannot figure it out just copy and paste one of them with the same name on the other ones
GSA190
Oct 29, 2007
401
New York
Ive done that for about 10 minutes and still their are 6 different album covers.
scandalex
Sep 16, 2007
771
If what you are doing hasn't worked, highlight all the songs you want to be on the same album, click "get info," put a check mark in the box at the bottom that says "compilation."
plasmo
Jul 8, 2007
123
Check the "Compliation" box after highlighting all of the files you want to group together.
I also use the program "Tag&Rename" which is very useful to ensure all your song Tags and CoverArt is correct (it has a cool search function to match the titles of the mp3s to amazon.com's library and pulls the coverart from their site)
http://www.softpointer.com/tr.htm
scandalex
Sep 16, 2007
771
I also use T&R...great program, but also had the coverflow problems mentioned here. When I first got my iPhone, everything showed up in coverflow as it was supposed to do. I don't know what happened, but then it stopped.
jay12
Oct 18, 2007
25
thanks for all the replies.. ill try checking the compilation box when i get home.. i know its a minor problem.. its just bugging me cause i can figure it out! :laugh2:
jwhcowan
Jul 5, 2007
29
Album Artist
I had the same issue last week, and it turned out that one song did not have:
Album Artist (not the Artist or the Name)
Check that matches too.....
Finally, did you try adding new artwork to all songs at the same time manually? Perhaps the actual JPG is different?
