iTunes deleted my new songs?
ChocolateMonkey
Mar 7, 2012
Okay so i bought some new songs and they were not syncing to my iPod they had little grey exclaimation marks against them i was going to try to fix ths problem today only to find when i brought up iTunes it had deleted all my new songs! I don't know how to get them back and they are not on my iPod, can someone please tell me how to get them back! I'm so annoyed with my iTunes and would like my songs back!
iphonewarrior
13,847
699
Everything you've ever purchased from iTunes can be downloaded a million times over, for free. You can see your purchase history by logging into iTunes.
Another option would be to launch iTunes, click Store then click Check for Available Downloads... it may prompt a download.
iphonewarrior
13,847
699
Erm, yes you can download them again. You've bought them, you don't have to re-buy them. :)
iphonewarrior
13,847
699
You click back on the song and re-download it. If you receive and invoice for them and Apple charges you twice, simply report it by pressing the 'Report a Problem' link within the invoice. It's that easy.
