iTunes Error
coryt87
Jul 24, 2007
68
"The software required for iPhone is not installed. Run the iTunes installer to removie iTunes, then install iTunes again."
I did that..and the same error shows.
I'm on 1.1.1 iPhone, modded with apps and on the newest iTunes. If someone could help me, that would be great :)
goobs22xx
Sep 16, 2007
250
If you or someone else is looking for a solution, i just ran into the problem and solved it (at least for my iPhone).
I uninstalled iTunes using the installer for 7.4.3 off the website. Instead of using their package for the install, I downloaded an older version of iTunes (just google it).
When I installed the older version, I went to Help->Check for updates. When I updated through iTunes it installed the newest version, asked me to restart, and sure enough, it worked out.
Hope this helped you out.
