iTunes issue
Aug 11, 2016
Hey guys!
I'm using Outlook 2013 for data storage. In order to sync it with my iPhone I use iTunes. It has always worked amazing and never failed until now. Something's wrong now because I'm trying to sync my Outlook calendar events and although it shows that the sync is in process, but nothing happens. I tried reinstalling iTunes, but it still isn't working.
Can anyone tell me what could be the problem? And is there any other way to sync Outlook calendar with am iPhone or make iTunes work?
Thanks beforehand.
Aug 11, 2016
Hey guys!
Thanks beforehand.
I guess I found a solution. The software is called AkrutoSync and it works fine with all my calendar events. Here’s their video tutorial that shows how to set up everything
The only difference is that there is no Mail, Contacts, Calendars section, it was divided into five different sections and you have to set up every type of data separately.
