iTunes Match not working 8.0-8.0.2 on iPhone 6 Plus
Shan S.
Oct 23, 2011
29
Is anybody having issues with iTunes Match not working with the iPhone 6/6+?
I have tried since I picked up the 6+ since day one... It has been updated to ios 8.0.2 but the problem has been there since 8.0.
On the phone my library never fully appears ( just a few artists and songs) nor do any play lists ever appear. Also if I try to download a song. It just doesn't happen.. It starts the download and then stops.
It seems to work fine with ios 8 on the iPad. So not sure what is going on.
I have the settings to show all songs and videos and have turned on iTunes Match.
While troubleshooting I fully reset the phone to factory and then tried too get match to work... Still had issues.. So pretty sure it is the software build for the new phones and not a hardware issue...
Anybody else get it to work? If so what did you do?
Shan
Shan
Dec 10, 2009
2,589
1,337
52
Clarksburg, WV
Worked fine for me. Over 2k songs populated when I activated the device and enabled iTunes Match:
Shan S.
Oct 23, 2011
29
Hmm OK thanks.. yes I posted in a few other forums too.. Does not seem to be a common problem..
Must be something with my account and how its set-up on the phone.
Shan
