iTunes not automatically opening when iPhone is connected
tharley46
Jul 17, 2014
I've got 2 questions about iTunes but I don't know if this is the right place. First question, when I connect my iPhone to my computer, iTunes will not come up automatically now, it use to. I have to click iTunes icon to bring it up now!!! What I am doing wrong now??
Second question, why is this "Automatically sync when this iPhone is connected" ( see photo with arrow pointed at the problem) being greyed out? It use to be in bold black with a check mark in the box. Now, it shows no check mark and it's greyed out and I don't know how to fix this. All help appreciated.
Sent from my iPad using Tapatalk
tharley46
Jul 17, 2014
I moved your post to a new thread since it was unrelated to the topic of the thread you posted in. Please update iTunes on your computer, check to see if this resolves either of the problems and then post what computer OS you are using.
tharley46
Jul 17, 2014
It's already updated to the newest version. Now what do I do? Still doesn't show the question asked earlier.
What Operating System are you running on your computer?
Rafagon
Dec 7, 2011
7,567
1,227
46
Miami, Florida
Windows 7 4 bit
That's probably the issue. You're not using enough bits. You should use at least a 32-bit version of Windows, but preferably 64-bit. :D
But seriously, is there a chance that you (or an application) has inadvertently disabled automatic iTunes launch when the iPhone is connected to the computer?
I would suggest you follow these steps, but when you get to step three, be sure that Enabled is selected, instead of Disabled. And don't forget step four ("Restart your Windows PC for the changes to take proper effect").
tharley46
Jul 17, 2014
Oh dang. My typing didn't print it all out. I'm using 64 bit windows. Sorry
tharley46
Jul 17, 2014
No problem. But I want it enabled, so I guess, just reverse the procedure, right
In iTunes go to Edit > Preferences > Devices. Make sure the box for preventing iPhones from syncing automatically isn't checked.
