iTunes not opening on iPhone 5
Jaccks
Mar 30, 2011
53
When I open iTunes on my iPhone 5 it immediately crashes, tried a reboot. Anyone aware of an issue like this going on. I am on ios7.
Sent using iCafe app
iPutz
Nov 20, 2012
962
184
43
71
US Midwest
Maybe try a hard reset and if that doesn't cure the problem, maybe updating to iOS7.0.2 will if you're still on iOS 7.0. Good luck.
Sent from my iPad3
Jaccks
Mar 30, 2011
53
Yep, those things have been done, still won't open.
RoofMonkey
Jun 21, 2010
8,876
2,049
Try a restore as new. Sucks, but could fix the issue.
28,365
5,506
Open the iPod app and then click the link for "store." That's an alternative way to open iTunes. You only have to do this once. Now close the iTunes app and try to open it the regular way and check if it loads fine without crashing. If it still crashes after that, change your cookie settings. Settings > Safari > Privacy and Security > Block Cookies. If it is set to "always" change it to "from third parties and advertisers." Having it set to Always can cause iTunes to crash.
Jaccks
Mar 30, 2011
53
Yay! It worked! Thanks Europa, you always seem to have the answers, much appreciated.
