iTunes on iPhone showing wrong album covers...
iPhoneGuy
Jul 10, 2007
The title says it all.. My iTunes on my phone is showing some albums incorrectly. Anyone else?
SuperDodge
Jun 24, 2007
23
Greenville, SC
If you look at the albums in CoverFlow mode does it show the right cover right up until the point where the album is front and center?
If so I experienced this problem and fixed it by unchecking the "Sync Music" option and then hitting apply. Once that sync finishes (removing all music from the phone), recheck the "Sync Music" option and then apply.
Worked for me.
iPhoneGuy
Jul 10, 2007
Worked for me.
What is really weird is that one album shows art of a group I do not have any songs from.. My Jimi Hendrix shows OkGo as the album art. But not on my Mac...
I will give that a try... It happens in album view mode but, i can scroll to an album and it will be wrong...
Doc Holiday
Jul 10, 2007
37
Las Vegas
Things to check
Sometimes when you have iTunes download the covers automatically, it'll load the wrong cover. If it shows incorrectly, in iTunes elect the song(s) with the wrong cover and right-click(pc) to get info. On the artwork tab, you can see the cover that was selected for the song. If it's wrong, select it and delete it. Now you can copy and paste the right cover. Then when you sync, the new cover should appear.I hope that helps...
