iTunes questions and a computer restore?
kenneth
Aug 19, 2008
1,465
Texas
im having a lot of problems with the pc that i have my iTunes account on. im going to do a full restore and erase everything and reinstall vista. my questions are will i have to create a new iTunes account? also i should be able to burn all of my music onto discs and then just reinstall correct? feel free to give any other advice.
gotzaiPhone
Jun 16, 2008
1,177
Tinley Park, IL
1. back up your iTunes library like you said and you'll be fine.
2. you will be able to use your same account, actually you have to for DRM stuff to work.
3. make sure to "de-authorize" your current iTunes after the back up so that it doesn't take away from your total 5.
4. authorize your new iTunes first before you put the library back on the computer.
You should be fine then.
