iTunes to iPhone Syncing Question
marcbkk
Jun 29, 2008
55
I just had to reinstall windows on my PC last week, which means I also had to put in a fresh install of iTunes again.
What is currently on my iPhone had been uploaded with my previous install of iTunes and I am about to connect my iPhone to the new install of iTunes. I recall from past experience that it will want to erase all music, video, and pictures from the phone and start it again fresh if what is on the phone does not match what is in the iTunes library currently.
I don’t mind this as I have all the movies, pictures, and music that were on the iPhone already backed up on a separate hard drive and can reinstall it all very easily.
But the issue is I had big problems before with iTunes messing up my contacts in Outlook and eventually l spent a lot of time hand loading all my contacts into the iPhone and no longer had it syncing with Outlook.
At this point I don’t want iTunes to touch my contacts on the phone and remove any of them and my question is if I don’t set my new installation of iTunes to sync with the contacts will it also erase all of my contacts when I connect my iPhone to this fresh install of iTunes for the first time?
Many thanks,
Marc
showguy
Dec 2, 2007
769
Long Island, NY
If you chose not to sync your contacts, iTunes should leave the contacts on your phone alone. Just make sure that you "DO NOT CHECK" the sync with contacts option in iTunes.
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
There should be an option to merge the contacts with those already on the phone, choose that option.
marcbkk
Jun 29, 2008
55
Thanks guys. All is well. Luckily everything was left alone by iTunes.
