iTunes wants to restore - I don't!
tulsa40
Dec 20, 2008
When I connect my 3G iPhone to my computer I'm met with the Set Up Your iPhone screen and am given two options in iTunes:
Set up as a new iPhone
or
Restore from the backup
I don't want to set up my iPhone as a new iPhone or restore it -- as far as I can tell my iPhone is working normally. All I want to do is sync. Is there anything I can to to get iTunes to let me sync with my iPhone?
Thanks.
iNinja
Aug 8, 2008
3,984
20
UK
Which firmware are you using? I would just humour iTunes and restore from a backup... Have you recently upgraded / downgraded firmware?
tulsa40
Dec 20, 2008
I'm using version 2.21. The only change I've made recently to my iPhone is to install Skype, but I haven't opened the app yet.
Ultimately, I may have to resort to the restore, but before I do I'd like to explore the alternatives, and see if I can figure out why this is happening.
kevlar08
Jul 3, 2008
1,140
Colorado
it is probably a flook, jus restore from back up and youll be fine
tulsa40
Dec 20, 2008
Thanks - I did that and everything works fine. (Oddly, restore took about 2.5 hours.)
evolution83
Mar 2, 2009
3,322
43
California
Hmm, I had this similar issue once. All I did to correct it was disconnect my iPhone and reconnect, then the message went away. :)
Sorry so late on the reply, though.
