iTunes will not detect my phone
Corrisa
Mar 14, 2011
Can some one tell me what to do it will charge via pc but my phone will not show up and I have tried 4 different cords I removed iTunes and reinstalled it but may be did not remove it properly thanks in advance
Kaki5591
Oct 13, 2011
11
I was having the same problem. I followed the instruction from the Europa's link and IT WORKED. I think that what it really took to solve the problem is that I had to uninstall everything in the exact order listed.
This is a partial list of what I did
.....previously, I just did uninstall of iTunes....the fix required that I follow ALL of the instructions in the correct order.
  1. iTunes
  2. QuickTime
  3. Apple Software Update
  4. Apple Mobile Device Support
  5. Bonjour
  6. Apple Application Support (iTunes 9 or later)
