iTunes with multiple devices
smooth915
Dec 16, 2008
East Bay Area, California
Buying a 3G 8GB iPhone. We currently have a couple of iTouches, a Nano all on one PC. Is there going to be a problem with adding the iPhone?
Tug
Aug 4, 2008
528
I've got 2 nano's and my iPhone and have not experienced any problems
Oct 3, 2008
27
If you want to manage several iTunes libraries and devices separately, you will need a 3rd party app such as iLibs.
15,385
1,089
yes, libraries are a different story. But the easiest way to share different libraries is to create different user accounts on the computer. If, however, you are using the same library, iTunes will handle multiple devices just fine.
