iTypefastR uninstall Froze Phone Help
Sep 16, 2009
I tried uninstalling iTypeFastR from cydia just now and got this message
"Software uninstalled successfuly. dpkg-warning: while removing itypefastr3x, directory '/var/mobile/library/iTypeFastR' not empty so not removed."
When I hit the reload springboard button, nothing happened. The loading wheel in the middle has been spinning for 10 mins, and the Reload Springboard button is blue, but the phone wont due anything. Both Home and Power buttons are unresponsive.
Am I Stuck? Do I just need to wait for the battery to die or is this crash a major deal that may force me to do a dreaded "restore" Any tips/help is appreciated.
I have a 32gb 3gs, running 3.0.1, just jailbroke it Thursday night.
Sep 16, 2009
Calling the phone and leaving a VM does nothing to interrupt the process. Guess I will have to wait for the phone to die and hope that fixes the issue. Hopefully it will be dead by morning...I mean it was at a full charge, but the screen is lit up now. And if all else fails, I guess technically I could restore it, take it back to ATT and try and get a new phone (still in my 30 days) but then the new phone I get could already have 3.1 on it. Grrrrrrr.
Sep 16, 2009
Nevermind. I read the instructions on how to do a hard reset wrong. Once I re-read them, the phone reset fine.
Jan 16, 2009
3,230
59
Mississippi
Glad you got it fixed. That hard reset does wonders. I was asleep when you reported your issue. Later
Jun 19, 2007
33,478
4,542
Upper Marlboro, MD
It seems to me that app was causing me all sorts of grief until I uninstalled it. For instance, text I'd type would suddenly begin deleting by itself.
