ive always wondered if this really helped battery life
DiscoJoey
Jun 5, 2007
307
i remember people use to say that if you left your ipod while the song was the middle of playing it had to remember the songs place so it drained more battery. is this at all true? and if so does the same apply for the iPhone?
TrippalHealicks
Mar 2, 2007
1,341
I'm sure every little thing the phone does, uses some amount of battery, but is it even a noticeable amount? Probably not. lol
tfg
Jun 20, 2007
213
No I don't think so. I think when you're not in an application, and at the home screen it's not draining the battery. If you look closely, the battery is gray, but when you're using the ipod it's green. When it's green that's when you're using an app. When it's gray, i think that's more the standby mode.
alb0zf1n3st
Jul 2, 2007
624
I highly doubt it .. even if it does it would waste like almost none on a scale of 1 to 10 like a 0.5 lol
velvetropeparty
Jul 4, 2007
56
not true at all. basically just like a computer in suspend mode. The information is on 'hold' and consumes no more power with information in the memory as opposed to when it is empty.
adseguy
401
A computer in suspend mode uses power, and a lot at that. The CPU, drives and such may shutoff, but power is hed onto the volatile ram.
The iPhone has both volatile and non volatile ram. Whether that ipod data is stored in the volatile or non-volatile part is the question. the answer either way is that battery life may be drained depending on the case above, but the amount of power to hold a few bytes of info for hours on end should be insignificant when you couple signal strength of the ATT service into the equation. Get my drift?
