I've just jailbroke......
lewisdg
Jan 5, 2008
21
and installed customize,summerboard and a few sound and image sets - but when I go into customize some of the image sets do not seem to be loaded in. Also when I change the carrier image part it stays as o2 instead of what I have selected. Plus when I add a background via the normal settings icon all I have is a black screen. I know that this picture works because I had it as my background before I jailbroke........am I being a complete idiot or is this normal - I have a ootb 1.1.2 phone
I'll also keep looking elsewhere for the answer but if anybody can help that would be great
cheers
Lewis
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
You can download an app. called "make it mine" in the installer. It will allow to change the carrier logo to whatever you want to type in. Hope this helps you a bit.
iCreep
Nov 14, 2007
84
Well if you have a theme set on summerboard prefs (SMB Prefs) and are trying to change the wallpaper make sure you turn theme wallpaper off or else it won't change. Hope that helped.
iCreep.
