I've just un-jailbroke.......
lewisdg
Jan 5, 2008
21
in prep for the new software update . I did this via a restore. All went well with no errors or anything but my carrier logo is still what it was when it was jailbroke........even though I did a restore it seems that some files are not 'reset'....do we know if these will be detected when I do do a software upgrade - and what are the chances of bricking?
Is there anything else I need to do to get my phone back to it's original 1.1.2 otb?
cheers guys
ArEa_CoDe_415
Oct 4, 2007
537
30
San Francisco
when you were jailbroken what did you use to change the carrier logo?.... If you used the app "make it mine" you should've pressed revert in that app before you restored your phone.
lewisdg
Jan 5, 2008
21
I did use 'make it mine' ......but didn't revert back - so how do I go back to normal? - just incase I ever need to take it in to be repaired or something
insocal
Jun 25, 2007
58
cheers guys
A quick fix for this is found at: www.macdaddyworld.com and download the CaptionCrunchCarrierString. I had to do it earlier as well and it could NOT have been easier.
lewisdg
Jan 5, 2008
21
thanks for the above replys.....the mac daddy fix requires you to have a mac of.....alas I have just a of
