I've tried everything (i think)
MKweik
Aug 6, 2007
I've been tryin to change my system sounds since 11 am this morning i have had absolutely no success and i have searched every where for help but i just cannot find the answer...can some one please help me put the system sounds on my phone using ifuntastic 2.5 or if there is another way...and yes i tried the hackmyiPhone like a 100 times and it didn't work for me....please help thanks...incase you needed them these are the files i want to put (i converted them to .caf before i tried putting them on they still didn't work) HELP! thank you
SiLeNtKiLLa
Jul 4, 2007
134
Atlanta
make sure you name them to the correct corresponding app...
SMS Received - sms-received.caf
New Mail - new-mail.caf
Use iPhoneinterface.exe or iPhonebrowser or manzana to transfer files over, if any of these work with mac.
I use manzana, browse to /System/Library/Audio/UISounds/ and copy them there...
*** oh yeah....it also could be the conversion, don't convert them in iTunes, but convert them in quicktime, as that was my issue before, and I ran into a thread I believe on here on how to correctly convert them, and now then they worked.... ****
I will see if I cant find the thread.
