iWorks issue
Target
Oct 16, 2008
1,139
168
The Great State of WV.
Hello,
I recently downloaded the iWork suite. In testing how docs would work through iCloud, I get this error message:
When I go to the App Store I see that I have it and no update is needed:
What am I missing to open the doc on the iPhone Pages app?
5,578
Try deleting and reinstalling it.
Target
Oct 16, 2008
1,139
168
Also the same result in Numbers and Keynote. Now if I create any docs in the iOS app, I can open them fine. But if I pull them down to iOS from iCloud, I get that message I posed above.
5,578
Try deleting it iTunes on your computer and on your phone, syncing, installing it on your computer and then syncing it to the phone.
5,578
Never sync'd to iTunes. Only through iCloud. Do you mean delete the docs?
Aren't the documents in the cloud? If so, deleting the app will not delete them. I would try downloading it in iTunes and syncing it onto the phone. If that doesn't work, it sounds like there is a problem with the app or the documents.
Target
Oct 16, 2008
1,139
168
Isn't this interesting: a Jan 23rd update. Odd thing was I check the App Store and there was no update.
Target
Oct 16, 2008
1,139
168
And we have a winner. Issue resolved. I was 8-hours ahead of the update. Wonder how that happens.
Thanks Europa for all the help.
