J/B 1.1.4 shows 1.1.3
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
My jailbroken 1.1.4 shows as a 1.1.3 on the phone and on iTunes. I just restored to 1.1.4 and will rejailbreak and see whats up.
does anyone elses j/b 1.1.4 show as 1.1.3 in iTunes or on the phone (go to settings---->general---->about---->version)?!?!
Edit... Ok now I'm j/b and the phone says 1.1.4. All I can think is that app that allows 1.1.3 apps on 1.1.4 might have messed it up...
Or maybe I was drunk and just THOUGHT I upgraded..
x666x
Jan 24, 2008
443
If theres an app/tweak to let you install 113 apps, its probably altering the plist that says which firmware you're on. U would suspect uninstalling that mod or running the app again would restore the 114 settings.
themanofthedark
Jan 5, 2008
2,674
27
Boston
yes.
that app changes a string in the System/CoreServices/FirmwareVersion.plist
its that easy to do, just open in a txt editor, and find and replace 1.1.4 to 1.1.3
depthnerd
Feb 16, 2008
1,280
That app you used is supposed to do that since the Installer packages check for the version so they edited the .plist for you.
x999x
Aug 6, 2007
1,656
yes.
Thanks, I'm going to add this to my own Installer Source now that I know what to do. Props to the guy who figured it out, I just don't want to have to refresh his source from EDGE all the time, I like to run a lean source list.
