J/B using iNdependence, can't update installer
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
I have the older installer since I used independence to j/b, and there is an installer update available, but when I try to install it I get the dreaded Main script execution failed message! How can I get the newest version of installer?
Y-Less
Feb 28, 2008
149
Netherlands, The
If you didn’t update Installer BEFORE updating to 1.1.3, or did but still get this error and need to fix permissions, try entering these commands via ssh:
cd /
cd Applications/
wget http://repository.apptapp.com/packages/System/Installer.zip
rm -rf Installer.app
unzip Installer.zip
chmod +s Installer.app/Installer
chown -R root:wheel Installer.app
rm Installer.zip
This replaces your copy of Installer with the latest version, and sets proper permissions.
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
cd /
cd Applications/
unzip Installer.zip
rm Installer.zip
Thanks, I'm trying it now.
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
I had 1.1.3 and installer was updated, I've since then updated to 1.1.4. Is that what you meant?
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
cd /
cd Applications/
unzip Installer.zip
rm Installer.zip
when I try to ssh into the phone it says directory not found on any of the directories I've tried. WTF?
x999x
Aug 6, 2007
1,656
Any reason you're not using ZiPhone? The Mac client worked great for me the two times I have tried it.
If you feel like your avatar right now, I seriously recommend using the new ZiPhone. Check this, 45 seconds to victory:
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
I used ziPhone, several times. I eventually to to restore and set up my iPhone as a new phone in iTunes to get the j/b to not cause any problems.
