Jail break
Jon101
Dec 24, 2008
South Florida
Hello everybody, I have a 3G iPhone and I'm thinking about jailbreaking it but I would hate to mess up my phone, has anybody had any problem with they i phone after the jailbreak? If so please let me know. Or if there is nothing to worry about. Thanks for the help.;)
JWB
Nov 8, 2011
120
11
Anyone recommend to jailbreak?
5,578
If you are running 7.1, you cannot jailbreak. If you are running
7.0-7.0.6, you can use evasi0n.
Full updates in iTunes are recommended if you are going to jailbreak. However, 7.1 is not jailbreakable, so it's too late to update properly. OTA updates can cause problems with the jailbreak and there is no way to fix that now if you did use the over the air option. It might still work if you updated OTA, so you can give it a try if you want.
