Jail Break
Sneekz
Jan 2, 2009
I Recently(yesterday) jailbroke my ipdo touch (2.2) im wondering if i should down grade and go for 1.1.4 or whatver it maybe
i need some suggestion what i should do
15,384
1,089
if you downgrade to 1.1.4, you will not have access to the app store or any of the apps from it. Furthermore, any jailbroken apps written from here on out are written for 2.2+, so they will most likely not work for 1.1.4 either.
So the only reason it would (maybe) benefit you would be if you were not interested in using any apps other than the stock Apple apps, which i presume is not the case since you are currently jailbroken.
Jayzay
Jan 7, 2009
nowhere
hey a lot of people say that you cant...but can you jailbreak an ipod touch version 2.2 2nd generation? Or did they not release it yet, because when i go on quickpwn and plug my ipod in the picture never shows up and i can never find the ipsw file to load>=\
Jayzay
Jan 7, 2009
nowhere
ill be back at 2:00 im kinda in school right now, send me an email though if you want at jay1zay@yahoo.com or just post it =)
Syncro_Fei
Jan 9, 2009
44
It is not possible to use the quickpwn exploit to jailbreak the 2nd gen. It's been re-engineered to make that exploit impossible. They have not found a new exploit yet, as far as I know, unless it was discovered in the past 12 hours.
