Jailbreak 1.1.3 using installer
seb481
Aug 3, 2007
774
San Diego
I noticed that there is a new app in Installer that does the soft-upgrade from your phone, without having to ssh anything. Have any of you tried it yet?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Yes I saw that when I jailbroke at 1.1.2 along with the cleanup app, which I did you the cleanup after the 1.1.3 jailbreak.
I don't know if I have read of anyone using the soft-upgrade app, or the how to use it?
Tinman
4,334
183
Aridzona
It's a rogue release, be careful with this. Could be OK, or maybe not.
Mike
koolhand79
Oct 6, 2007
54
KILLA CALI
It does work. I just upgraded with that software. I haven't tested anything out yet tho.
Tinman
4,334
183
Aridzona
Yeah I just saw this at Mod MY iFone
Good luck in trying to get on that site, it is always down.
yes that site is turning into a joke. Last month they said all the problems would be gone due to a new server. Looks like that didn't happen.
HORRIBLE, if trying to view forums (unless you like to take a coffee break between pages).
Mike
koolhand79
Oct 6, 2007
54
KILLA CALI
So far it seems everything except the locating feature in maps works fine. I tried installing locateme but it doesn't seem to show up when i install it. Other programs seem to work fine such as iswitcher and NES
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Mike
I just tried like 6 times to read the MORE page to copy the howto, but it just crashes each time. But they were saying how to use that installer version
enigmanic
Jun 27, 2007
513
Just tried this method on another iPhone and it seems to work fine. I'll report back if I have any issues. For those of you who can't access the "Read More", it states that you must have the following, prior to running this softupgrade:
1. A jailbroken 1.1.2 phone
2. The latest version of BSD (version 2.0).
3. The latest version of Installer (version 3.0b10)
4. Autolock set to Never.
It's recommend that you do this over a wifi connection.
The entire process took about 20 mins. I still have to create symlinks to fix the syncing issue, and of course use LocateMe to get Google Locator to work.
seb481
Aug 3, 2007
774
San Diego
Could you please try google maps locator, and more importantly, try to sync your contacts and calendar with iTunes. They were reports that contacts don't sync. Let us know. thanks
enigmanic
Jun 27, 2007
513
Are you referring to the contact syncing issue? If so, how do you create symlinks?
Yep, I am referring to syncing contacts, mail, bookmarks, etc. See this link on how to fix it (thanks Tinman):
http://hackint0sh.org/forum/showthread.php?t=25796
Koolhand,
You're right..i'm having the same issue too with certain apps. Some will install just fine, others will crash.
koolhand79
Oct 6, 2007
54
KILLA CALI
Well so far the apps that show up seem to work fine i just cant seem to get locateme to show up at all on the springboard. other than that and the contact syncing issue im fine. I don't particularly understand all symlinking stuff
seb481
Aug 3, 2007
774
San Diego
ok, so that confirms the installer jailbreak also has contact syncing issues.
sab3083
Oct 4, 2007
14
i just used this method, and i go to installer and all my 3rd party apps are still listed as being installed from before, but theyre not on the springboard. what do i do to get them to work and show up on springboard?
seb481
Aug 3, 2007
774
San Diego
Uninstall then and re-install them. It should work. Also, please try to create a new contact in your iPhone and sync it with iTunes to see if it works and report to us. thanks
sab3083
Oct 4, 2007
14
ugh i gotta reinstall everything, man this is going to take hours
