Jailbreak Detection help
19birel
Mar 29, 2012
Economy, Pennsylvania
I was wondering if you guys could tell me which appstore apps have the jailbreak detection software so I can decide if I want to Jailbreak my 4S. Here are the apps that I would like to know about. Any input helps! THanks
Skype Shazam Nike+GPS Photoshop Express
Gangstar Rio Fruit Ninja Pocket God
If anyone can confirm that one, some, or even all of these apps work or don't work on a jailbroken device that would be great. Thanks again!
All of those apps will work fine on a jailbroken iPhone. You'll get a jailbreak detection warning the first time you open Skype, but you can just ignore it. Skype works perfectly fine on jailbroken phones; it's just that Skype won't provide tech support for the app unless the phone is stock. As far as I know, there is only one app that is disabled by the jailbreak, Optimum TV, and there is a way to enable it again and get it working. So no worries, you can go ahead and jailbreak. :)
19birel
Mar 29, 2012
Thanks for the responses everyone, looks like I'll be jailbreaking it! As far as what jailbreak to use I was thinking of going with RedSnow because that's what I had on my old iPad one but since I'm putting this software on an A5 is there a better one? Thanks.
Use Absinthe if it's on 5.0 or 5.0.1. There currently is no jailbreak for a 4S on 5.1 and there is no way to downgrade the firmware.
greenpois0n.com/
