Jailbreak for 3.1
KrakaJap
Jul 7, 2009
1,620
25
41
IL
So how soon do we think the 3.1 jailbreak will be out? :)
I'm assuming the normal 3.0.1 jb process will not work for 3.1?
I don't want to lose all that screen real estate and custom font! :p
28,365
5,507
The best we can do is surmise that the Dev Team will have available within a few days.
cdgarcia87
Jun 14, 2008
39
has there been any luck on the jailbreak for 3.1? i have the 3rd gen 64gb touch and want to jb it
KrakaJap
Jul 7, 2009
1,620
25
41
IL
http://blog.iphone-dev.org/
It will be posted there before anywhere else. :) right now there is not but be sure to READ the top post on that page before you do anything! It states very clearly that the current release does NOT support the 3G iPod.
seanwes
Feb 13, 2008
1,667
San Antonio, TX
Haven't been keeping up with the unlock situation as I'm with AT&T, but had a client ask if the 2G and 3G are currently unlockable on 3.1? Apologies if this has been asked.
KrakaJap
Jul 7, 2009
1,620
25
41
IL
Yes as long as they haven't been updated to 3.1 already and I'm not sure there's a full proof method of downgrading. I don't pay much attention to 3G or prior as I only have a 3GS but the dev-team blog has all the information on this. :)
K
kobeshaneisback!
Guest
blackra1n
that did the trick
KrakaJap
Jul 7, 2009
1,620
25
41
IL
Yes it did very quickly too :) but I'm wondering if the new pwnage tool is better. Devteam is very particular about makig sure their solutions work on every device flawlessly.
K
kobeshaneisback!
Guest
naah u still hav to do all that custom firmware stuff
cdgarcia87
Jun 14, 2008
39
i have already upgraded to the 3.1.2 software on my iPod touch.... will blackra1n cause a problem? or should i just wait till the dev team makes progress....
KrakaJap
Jul 7, 2009
1,620
25
41
IL
Both solutions are available now. I used blackra1n and haven't had any problems at all (3GS 3.1.2). However, there have been a few reported issues with blackra1n. I'm not sure about devteam's solution but they have always been good about making sure it's 100% ready before releasing anything. Granted it is a longer process of course. :)
K
kobeshaneisback!
Guest
if its a 1st or 2nd gen just do it it works perfect for ipod on windows and there is a mac version too.IF YOU HAVE A MAC AND HAVE ALREADY JAILBROKENON 3.0 OR 3.0.1 U MAY TRY UICKPWN BUT I RECOMMEND THE EASIEST UICKST SOLUTION:BLACKRA1N
KrakaJap
Jul 7, 2009
1,620
25
41
IL
I've heard that blackra1n is a tethered solution in that if you ever reboot the phone you have to have it plugged in and blackra1n loaded. I've rebooted my device multiple times and even turned it completely off and back on without having to plug it in. :/ is this only if you were to let the battery completely drain?
K
kobeshaneisback!
Guest
no thats only for ipod touch 3rd gen
