jailbreak help!
pootermoney
Aug 25, 2007
30
im trying to jailbreak not unlock and im trying to build the ipsw..and i get an error message saying i cant do it....i select cydia and custom images and deselect activate phone.and click build and it doesn't work..any solutions?
michael180
Jun 14, 2007
1,249
Santa Cruz, CA
moderntimes.com
You should probably restore as new phone, and re-jailbreak with Pwnage tool.
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
When your setting up the custom IPSW there's a tab at the end that lets you change the partition size. Bump it up a few megs and see if that helps (504-506 should be good). I had the same issue and that's what worked for me.
