Jailbreak on another computer
aaronsiphone
Dec 28, 2007
297
Quick question, is it possible and safe to jailbreak on someone elses computer? I am away from home for the week and would like to jailbreak!
KabaModern
Mar 31, 2008
4,549
32
Philadelphia, Pennsylvania
I've never done it but I don't see logically why it would cause any problems. You're not doing anything through iTunes. You just need the redsn0w software and the 3.0 restore ipsw.
aaronsiphone
Dec 28, 2007
297
ive jailbroken before, I also cant see any reason why it wouldn't work.....just checking if other people have done it. im on XP (well this PC is on XP) got an iPhone 3g running 3.0
aaronsiphone
Dec 28, 2007
297
I wont be able to syne for a while, will that be an issue.
which jailbreak software would you recommend
morth58
Mar 17, 2008
174
on occasion i will have an issue where a restore is needed - but for the most part just a straight jailbreak will go off without a hitch. I j/b about 4-5 five friends phones when they want it done. only had it happen a few times they had to restore after hooking to iTunes, so they brought it right back to be done again.
i used red snow - for the 3.0 software.
aaronsiphone
Dec 28, 2007
297
has anyone know where the ipsw is for 3.0?
iphonewarrior
13,847
702
the software you use (totally upto you whatever you use- pwnage/redsn0w), they create custom FW and you restore your phone to it. It's that simple.
D-Wade
Aug 26, 2008
69
Singapore
Can I use this in Pwnage?
Have downloaded few ipsw, it doesn't seem to work, incorrect bundle they say
5,578
PWNage Tool will make a custom ipsw file. To answer your original question, yes it's just fine to JB on another computer. Once it's jailbroken, just sycn it with the computer you normally use.
14u2nv
Dec 7, 2008
40
yeah, I j'b my own, my cousins and my brothers phones all on my puter, then they just syncd on their own. No issues
