Jailbreak Sync
mblahforu56432
Jul 6, 2009
33
Is there a way to sync a jailbroken iPhone cydia and other apps not downloaded through the iTunes store? They are not syncing with my iTunes.
mblahforu56432
Jul 6, 2009
33
is there a cydia application that enables it?
cliffeman
Oct 13, 2007
2,142
80
Feenix, Amizona
i don't believe there is one. Why do you need them to sync to iTunes? They don't get saved when you update to a new firmware. You have to reinstall them after each jailbreak. There are apps available that back them up and reinstall them when you have to rejailbreak.
mblahforu56432
Jul 6, 2009
33
so one of those apps would be..AptBackup in Cydia? are there any others or a better one?
cliffeman
Oct 13, 2007
2,142
80
Feenix, Amizona
there are a few others. Aptbackup (i've used before, works great, if you follow the instructions to a T), Appbackup, Chronus.
