Jailbreak ?
inletdoc
Jan 11, 2007
39
I just jailbroke my phone using the Pwnage tool. After restore, I have no connection to the ATT network, and all calls are immediatey listed as "call failed". Can anyone help me restore my network connection so calls can be made. Thanks
inletdoc
Jan 11, 2007
39
this is a V1 iPhone, by the way....
You'll most likely have to re-jailbreak, as this is the only the fix in this situation. When using PwnageTool, be sure not to check "Activate Phone" if you are using Expert Mode, if if using Simple Mode, tell PwnageTool that you are a legit AT&T customer.
Witness
Jun 18, 2007
1,471
27
Miami,Florida
yes i had the same problem you have earlier today and what Lincoln said fixed it .
inletdoc
Jan 11, 2007
39
I have network coverage now, and I'm in the process of syncing now. Before When I had no network coverage I downloaded NES and intelliscreen, and neither worked. Do you think this will fix that
