Jailbreaking 3GS
dobymax
Oct 19, 2007
238
Hey guys. I'm thinking about jailbreaking my iPhone 3GS. I'm doing it in Windows and will be doing redsn0w. My question is how do you tell what baseline you're on? I understand that it will only work om 3.0, or am I wrong?
Thanks in advance.
iNinja
Aug 8, 2008
3,984
20
UK
I would use purplera1n.... works so much better and quicker. Until the 3.1 release all 3gs's will be on the same baseband. To check which you have I think you can tap general and then about
dobymax
Oct 19, 2007
238
Croucher - thanks for teh quick reply. When I go into settings and about, what do look for? Thanks.
shutter13
Jan 8, 2009
2,208
153
modem firmware. And the modem firmware will only prevent an unlock. I was beta testing 3.1 which does update your baseband, and downgraded (still have the updated baseband) and jailbroke with purplera1n. No issues.
dobymax
Oct 19, 2007
238
Just finished doing a restore and was wondering if there is a place where I can get a guide on how to run either redsn0w or purplera1n. Tkanks.
shutter13
Jan 8, 2009
2,208
153
Purplera1n Mac
Purplera1n Windows
Redsn0w Mac
Redsn0w Windows
Purplera1n is the easiest jailbreak I've done, but when I jailbroke my 3G with redsn0w it wasn't exactly hard either.
dobymax
Oct 19, 2007
238
Got it. Thanks.
rocco
Jul 4, 2007
27
so i am deciding if i want to jailbreak my iPhone 3gs, i had jailbroken my v1 twice and had no problems with the whole process. I am just wondering if i can jailbreak the phone and then just simply do a restore to any of Apples update softwares and not brick my phone?
5,578
You can restore when ever you like. The purplera1n JB is quick and simple.
purplera1n.com
iNinja
Aug 8, 2008
3,984
20
UK
Also its really unlikely (at the moment) that you will fully brick your iPhone, usually a restore will fix the problem
taffam
Sep 14, 2009
Hi All
I am going to jailbreak a 3gs running 3.0.1 today, but some posts are saying to point redsnow to the 3.0 software, and some are saying that I should point to 3.0.1
Does anyone know what is the best software to use?
taffam
Sep 14, 2009
Thanks for that
The jailbreak seemed to work, but having issues with Cydia displaying host unreachable messages when trying to install apps from Cydia
Any ideas why this is happening?
ipwn3gs
Jul 12, 2009
155
Thanks for that
thats ussualy happens when a repo is offline.... ( unreachble! )
taffam
Sep 14, 2009
Hi there
I understand that, but I am able to access the apps through another phone
daycheck
Feb 27, 2008
157
Logan utah
www.tosque.com
HELP HElp!
I have a problem... I just got my phone yesterday from Apple store.. it has 3.0.1 Running the latest iTunes ... trying to jailbreak but redsn0w freezes up on the waiting for reboot.. and yes.. I have tried to unplug the cable.. waited 10 minutes then unplugged.. tried to unplug right away.. left it unplugged for like 10 seconds then plugging it back in.. still redsn0w (v0.8) stays on the waiting for reboot.....
any ANY help at all...
running WinXP Pro
iPhone 3GS 32gb on factory 3.0.1
iTunes 9.0.0.70
redsn0w 0.8
ANY help would be great ;)
taffam
Sep 14, 2009
Are you using the 3gS 3.0 software?
Even though your firmware is 3.0.1, you have to get Redsnow to point to the 3.0 ipsw file - you can get this from iclarified
Worked for me earlier today on a 3gS on 3.0.1
Rednow should also be version 0.8
And only install Cydia, don't put Icy on (make sure it's unticked)
daycheck
Feb 27, 2008
157
Logan utah
www.tosque.com
Yes using the 3.0 in redsn0w....
taffam
Sep 14, 2009
Sorry mate - out of ideas
I jailbroke one today and it worked fine just by following the redsnow instructions
Load the ipsw hit next, let it load the kernels etc then unplug the phone when it tells you to, turn it off and wait 5 for seconds after it has shut down, then hold the home key and plug the usb back in and only release the home key once the Apple logo disappears and the iTunes device comes up on the screen then let it do its thing
Thats all I did and it worked for me
