Jailbreaking fix for iPod touch
Y-Less
Feb 28, 2008
149
Netherlands, The
Hello everyone.
For the last few days posts has been seen about the ZiPhone 2.5 (or lower) and the device iPod Touch, Huge problems while jailbreaking the iPod touch and the message "Spamming AT, waiting for a response".
This fix works on iPod Touch devices with 8GB, 16GB and higher!
Okay. Here we go (Please follow my guide and do not change to any own direction)
  1. Put your iPod Touch in restore mode and restore to the latest version in iTunes.
  2. When done restoring please close iTunes.
    (Just close iTunes, do not end any processes or services.. Just close iTunes)
  3. Download the follow package and unzip wherever you want:
    Mirror 1: http://ric.themoon.googlepages.com/jailbreak.zip
    Mirror 2: http://www.sendspace.com/file/c4fqoy
    Mirror 3: http://rapidshare.com/files/98335286/jailbreak.zip.html
    Run the follow file "run.bat" TWICE!
  4. Your iPod Touch 1.1.4 will be jailbreaked and installer.app will be installed.
Okay childeren, Now stop posting those annoying same topics over and over agian! Happy policehunting (Jailbreaking.. get him?) Damn im good..?!
depthnerd
Feb 16, 2008
1,280
Thanks a bunch. I felt really bad after misleading a friend and having his phone being permanently fucked.
jasonq
Mar 5, 2008
Thanks so much, Y-Less
Thank you very much, Y-Less. I spent so much time trying to figure out why I was getting the "spamming AT..." error to no avail, and your fix solved the problem in two minutes.
Firerfly
Mar 5, 2008
Y-Less, you posted all the directions there, but that means that your iPod touch has to be found on iTunes, my iPod touch is not being found. Any advice?
jjsquizz
Nov 10, 2007
252
Los Angeles
Hello everyone.
For the last few days posts has been seen about the ZiPhone 2.5 (or lower) and the device iPod Touch, Huge problems while jailbreaking, Message's like "Spamming AT, waiting for a response".
Okay. Here we go, This is a universal fix (Please follow my guide and do not change to any own direction)
  1. (That will be 1.1.4, So do not use SHIFT-RESTORE, but just click restore in iTunes)
    [*]When done restoring please fill in the iPod's name in iTunes and unselect sync.
    (You can skip it but its advised to do, I do not know why?)
    [*]Close iTunes
    [*]Download the follow package and unzip wherever you want when your mood says so: http://ric.themoon.googlepages.com/jailbreak.zip
    (And run the follow file "run.bat" TWICE!)
    [*]Your iPod Touch 1.1.4 will be jailbreaked and installer.app will be installed.
    (If it fails, and that will be 10% because i've tested this on 5 different iPod Touch's today. Just follow the steps agian. If nothing happens, Please post on the forums for help).
Update: If jailbreaking was successfuly please use "Thank you" so I can keep a tracklist of successfuly jailbreaked iPod's.
Quick question. After this jailbreak, will the icons wiggle? This is a must for the person i am doing this for. It's a girl. lol
Mar 8, 2008
When I try to download the file thing I just keep getting this message. The bandwidth or page view limit for this site has been exceeded and the page cannot be viewed at this time. Once the site is below the limit, it will once again begin serving as normal. How long do i need to wait for?
depthnerd
Feb 16, 2008
1,280
I re-upped it for you on sendspace. I know you see that Thanks button. :laugh2:
Mar 8, 2008
1.1.1
I was able to install the installer app with 1.1.4 but everything in the installer app says you need 1.1.1 firmware. What should I do about this?
