Jailbreaking iPhone 4
Moved to iPhone Jailbreak.
The pros outweigh the cons, IMO. Voiding the warranty doesn't even need to be factored in. You can restore to factory settings if you need to take it in for warranty work. Most of the problems and hassles you hear about are related to unlocking. Since you're already on AT&T or Verizon, you don't need to worry about preserving the baseband to remain unlockable, so the process will be far easier.
Jailbreaking is really easy to do. Some of the jailbreak tools only take a couple minutes. You'll always want to go with an untethered jailbreak. Tethered jailbreaks require a computer to boot. All major iOS updates have untethered jailbreaks, but you'll need to skip some of the smaller ones, such as 4.3.5, to retain an untethed jailbreak. Sometimes the firmware update is nothing more than a patch for the vulnerability that allows the jailbreak on the previous version. You can have the best of both worlds by staying on the older version and keeping your untethered jailbreak while patching the exploit through Cydia. It's fine to restore from a backup that was created on a jailbroken device.
Cons:
1. A teensy, tiny bit of lag. It's usually not even noticed unless you're using an older iPhone model. I notice that stock apps take about 1 second longer to open, but that's about it.
2. Battery life might be slightly decreased.
3. You can't hit that update button in iTunes the second it appears. Well, you can, but you'll temporarily lose your untethered jailbreak, so it's best to wait. If you do this anyway and then decide you want to roll back the firmware, you can do that as long as you have your SHSH saved. They are automatically saved after the first one.
Pros (There are a lot more than this. These are just some of the highlights):
1. The freedom to do things outside the scope of an application and the ability to install apps that were not approved for the App Store for various reasons.
2. Fast access to settings toggles.
3. Full access to the file system.
4. Customization and theming.
5. Custom gestures and buttons for features, such as a springboard pinch to activate the flashlight.
6. Managing photos and videos on the iPhone (create folders without iTunes).
7. Enhancing stock apps. Add a download manager to Safari, save attachments in email, add a download feature to YouTube, pull to refresh Safari, access WiFi only apps, such as FaceTime, on 3G, and add a navigate button to Maps (opens in Navigon or TomTom).
8. Live weather on the lockscreen and springboard.
9. Accelerate animations in the GUI.
10. Add more folder options and improve the task switcher.
11. Enable iOS direct printing (AirPrint) for non-supported printers.
12. Bluetooth media file transfers between iDevices.
13. Better text messaging apps. Send and reply to texts on the lock screen and from within apps.
14. Action Menu customizations. This adds additional functions, such as favorites, dial, and to bottom, to the stock cut, copy and paste functionality.
15. Add a user agent faker toggle so you can quickly switch between mobile and full site website browser user agents.
16. Free tethering.
17. Managing music without iTunes.
  • Like
Reactions: Napoleon_PhoneApart
Rhon loudermilk
Sep 3, 2011
After investigating further service administrator is still in charge of my phone.I did restore to new phone and things cooled down.just today I restored backup and things started again.I do have a suspect and my x is just responsible for giving password to someone else.I am really pissed I have apps in my account that chase services are taking off.other apps were paid for with pay pal by whoever done this.I refuse to get another phone which Apple is willing to do until I catch this person red handed.he did in fact insinuated over the phone that he had a hacker do this and that I could probably take my phone apart and find a bug.this is crazy I have Verizon and Apple involved and have to take my phone 3hours to a Apple store.is their any app that I could download to turn it on and off.not to mention my car was broke into and computer stolen.what can I do to pay them back?
Why not just restore to factory settings and be done with it. You'd experice the same problems if you restored a new iPhone from this old backup, so a new device is pointless. You just need to start from scratch on your current iPhone. It might take an hour to set everything back up, and you'll lose a couple things, such as game saves and bookmarks, but I think it's the best and quickest solution to this problem.
Rhon loudermilk
Sep 3, 2011
You right just trying to prove a lot of things.Not to mention how pissed I am.I will restore as new phone asap.I guess it has totally comsumed me for the last 3weeks.Do you know of any app that I can download to do anything to mess with him while I have this restored to back up on sept 1?
Rhon loudermilk
Sep 3, 2011
My safari won't hardly let me do much.I should have known my iTunes icon came on when I restored as new other day.didn't notice it was gone before.
The restore should fix the Safari problems as well. Be sure to backup your contacts before the restore. You can sync them back on afterwards.
