Jailbreaking Problem
pizpaz
May 1, 2009
Hi All,
I recently purchased a 1st gen iPhone, I previously had an iPod touch which was jailbroken.
I am now trying to jailbreak my iPhone, which has the 2.2.1 firmware. I have tried 2-3 times using quickpwn... each time I get to 9 seconds on the third stage.. iTunes interrupts me saying that my iPhone is restarting in recovery mode, and the jailbreak is unsuccessful.
Am I getting my timings wrong or is there a setting where I can disable the pop-up so that I am not interrupted when starting in DFU mode?
Josh
MrEous
Dec 11, 2008
649
Dallas, TX
Are you using the correct ipsw file? There is a 3G version and a 1st gen version, iirc.
pizpaz
May 1, 2009
I found my problem... I assumed that using the USB port on my iMac's keyboard would be considered a 'USB hub' instead I used a separate hub and it worked fine. I now have a jailbroken iPhone :D
Thanks for your suggestion and help.
Josh
