Jailbroken 4S...now what?
needsdecaf
Jan 12, 2012
Jailbreak noobie here. Hell, iPhone noobie! I've had rooted Android phones so I understand the basics, but not sure how to theme, etc, my newly jailbroken phone. Been playing with Cydia and see if I can purchase themes there. However, do themes do nothing other than change the application icons? Is there a way to have more screen freedom? Add Android like widgets?
Looked around for a tutorial but haven't seen anything.
Thanks!
No, you can theme the entire interface. The best themes will be ones that you put together yourself. They'll also be free.
iphonewarrior
13,847
699
When/if I get the 4S I probably won't theme, but, if I do i'll do exactly the same. Creating your own theme from existing themes is by far te best thing to do.
needsdecaf
Jan 12, 2012
And what is the best way to do that? So far I've loaded a bunch of free themes on Winterboard and selectively applied them. Also picked up some cydia mods. But looking for more. Suggestions on how to do so?
iphonewarrior
13,847
699
Do you mean creating a custom theme?
chazm
May 1, 2008
729
40
I've never cared much for themes but if your looking for stuff to get on cydia I would suggest
User agent faker
Unlimtones
SBsettings
Navigate from maps (if you have navigation)
My3g
Infinidock
Gridlock
BiteSMS
Just to name a few
iphonewarrior
13,847
699
User agent faker
Unlimtones
SBsettings
My3g
Infinidock
Gridlock
BiteSMS
Just to name a few
Navigate from Maps is probably the best tweak I've ever used. Apart from SBSettings ;)
iphonewarrior
13,847
699
You can use iFile to move files around on your iDevice. You can Copy & Paste files too. Creating a custom theme, iMo mainly involves the icons, the wallpapers and surrounds tweaks are a totally different entity.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Its always good in the beginning to mix themes using ifile, just to learn where everything is, That's how I learned. Once you do that you can pretty much change anything you want and make it your own. From carrier logos to signal bars to icons and docks. And now with the notification center it's even better, more theming to do :)
Kadelic
Jan 4, 2010
4,957
1,609
Dallas, TX
I agree with all three of y'all on the theme thing. Among many others here, Europa and iPhonewarrior in particular helped me learn to use iFile and accomplish all sorts of theming tasks.
FolderEnhancer is one of my favorite tweaks and one of the first I'll install when I jailbreak my 4S. I'll also be checking out Sprintomize 2 which offers an large amount of customization features in one easy to use app. With all that said I can't take it anymore so I'm off to jailbreak this bad boy! :cool:
  • Like
Reactions: iphonewarrior
