Jailbroken iPhone 4 keeps crashing when making phone calls?
john_T
Dec 29, 2007
688
NYC
It's been happening since last Friday night. Should I restore? There are some texts I want to save. Is that possible? Also is the latest iPhone update jailbreakable? I'm JB on 4.2.1 and I really don't want to restore. Can someone help me out here?
iphonewarrior
13,847
701
The latest update is jailbreakable and it's un-tethered.
I would restore if stock apps are crashing. Copy your themes folder and use PkgBackup (or something similar) to copy your Cydia packages. Then restore to 4.3.3 and re-jailbreak using Redsn0w.
28,365
5,506
Have you tried a hard reset? Is it causing springboard/safe mode crashes is the app crashing? Did you install any new apps in Cydia the day this started? If so, uninstall it/them and see if it solves the problem. You can backup your sms.db file prior to restoring and then overwrite the file with your backup after restoring and rejailbreaking with redsn0w. The file is located in var/mobile/library/sms
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
I actually started having Safari crash for me, than I did a hard reset and it's all fixed. I'd go with Europa's solution before updating/re-jailbreaking.
As previously suggested, I'd install Crash Reporter and see what apps are causing the crash. Before I hard reset, I checked Crash Reporter and removed one of the apps that was reported as a tertiary suspect. I left the other app, that was also listed as a tertiary suspect, WeatherIcon, because I can't live without it. lol
john_T
Dec 29, 2007
688
NYC
Thanks for the tips. I just removed MCleaner, which I installed that day (completely forgot about that!) and it seems to be working fine now. I'll see how everything works for the rest of the day before restoring. Thanks!
Jun 1, 2012
Hoping this works for me too! Was frustrated that I was having such ridiculous phone issues until I saw that MCleaner might be the issue. I'll keep you posted!
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
So, I don't have to retheme again at the next jailbreak update, how do I copy my themes folder. I use PkgBackup but it doesn't copy everything.
Dec 15, 2008
5,386
340
Pensacola, FL
This may work. It opened perfectly on my desktop. Do you have iFile? If you go into iFile through SSH, you can go to var/stash and drag themes folder to your desktop. However, sometimes themes have a tendency to revert back to default.
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
Mike, yes I have iFile, but I have a Mac, not PC, if that matters. How do I go into iFile through SSH?
Dec 15, 2008
5,386
340
Pensacola, FL
I have a Mac as well. If you open up iFile on your iPhone and then click the web server image on the bottom, it'll give you a website to go to on your Mac. You're basically connecting to your iPhone IP address.
EverythingApple
Jul 28, 2010
3,862
225
North Jersey
Awesome! Thanks, I never knew that.
