Jailbroken phone shows 195MB of Other, is this normal?
scholls22
Jul 15, 2008
58
I was having trouble with my jailbroken 3G so i did a restore on the phone. I restored to a new phone and had 195MB of "other"....I then did a complete reset of the phone thinking that would wipe it clean. It was still there....Is this just part of the 3.0 OS? Im syincing right now and its installing the apps and the "other" file size is growing but its just installing apps.
any ideas?
doron
Apr 17, 2007
1,141
tampa, FL
any ideas?
just like Napo- said it is normal for you to have that amnt of "other" MB...i'm not a guru but it has something to do with phone platform itself...but go to settings>safari>clear cookies-clear cache...and if you have email accnts set up...empty out your trash...maybe that will help
shutter13
Jan 8, 2009
2,201
144
But do keep your eye on it...if it really spikes, you may end up with a lot of space being used up by the "other" category. The more stuff you add the bigger it will get, but a huge spike from one sync to another...you will need to restore to fix it.
28,365
5,507
any ideas?
That's where the OS is stored. A few hundred MB there is completely normal. Notes, SMS, Settings, and a few other things are stored there as well.
BigCiX
Jul 11, 2008
1,445
Bakersfield, CA
If your using Microsoft outlooks then all those contact plus their contact pictures are also part of that other.
ashwini
Jun 2, 2009
334
India
www.ashwini.co.in
I don't think so. The OS is not the others. Correct me if I am wrong, but doesn't the OS have a different partition, one that iTunes doesn't show?
ct2k7
Jul 7, 2009
145
I was going to point that out, however, I can't seem to find the other partition, and I set up my phone as new and 255M was still being used by "something".
