JB Types
darshanr
Apr 7, 2009
Toronto
Hi is there different types of JBing? QuickPwn is one that I know of are there others? Are there advantages to using one over the other? I find QuickPwn made my phone slow. Thanks.
Adam1389
Nov 20, 2008
588
Ilwaco, WA
QuickPwn shouldn't slow the phone down at all, the apps you install from Cydia might though
5,578
There aren't different types of Jailbreaking, but there are different programs you can use to do it, such as QuickPWN and Pawnage Tool. I've only used QuickPWN and it is available for Macs and PC's. Jailbreaking is well known for causeing lag. It is worse for some than others. I really don't notice it at all.
