Jb using redsn0w and preserving my baseline after using pwnage tool Question
wildturkey
Aug 14, 2007
168
I JB using the pwnage tool to preserve my 01.59 baseline on 4.3.3....but now i want to get multi gestures and it says i can use redsn0w to get it my question is when you start redsn0w and need to direct it to an ipsw do you go to reg 4.3.3 or the custom one created by the pwnage tool?
Please help thanks........
iphonewarrior
13,847
702
Thread moved to the iPhone Jailbreak section.
iphonewarrior
13,847
702
I don't know if that will work. I might work.
When you run Redsn0w RC16 make sure you deselect the "Install Cydia" box but make sure you check the "Enable Multitasking Gestures". Point Redsn0w towards the official stock 4.3.3 .ipsw.
