JellyLock7 has been released for the iPhone. It is my favorite lockscreen tweak. Here's the link:
JellyLock7
JellyLock is a lock screen app launcher, that is super convenient to use. Drag a grabber to your favorite application to launch it without unlocking your device first. In this version you can:
JellyLock7
- assign up to 5 app shortcuts
- optionally disable pass code skipping (see below)
- disable the default unlock method (You won't be able to simply swipe to unlock without the grabber)
- hide the default camera icon
- disable badges (enabled by default)
- disable the background blurring (enabled by default)
- change the circle color (default is transparent, as seen in the screenshots above)
- change the circle size
- change the opacity
- Show all
