Just purchased my 2nd iPhone and needed some info
Vulture
Dec 12, 2007
I just bought my 2nd iPhone (first one had a tragic death at the beach) and was told it could not be hacked into because it comes with version 1.1.2 firmware. Is this true? Is there anything I could do or am I stuck with a $400 paperweight until 1.1.2 becomes hackable?
termleech
Sep 7, 2007
1,154
McPherson, KS
OOTB 1.1.2 can be jailbroken, it just can't be unlocked. So if you are looking to jailbreak it, just follow the normal instructions for 1.1.2, which involves downgrading, jailbreaking, oktoprep then upgrading.
Vulture
Dec 12, 2007
Thanks for that clarification. Is there any hope that 1.1.2 will be unlocked or should I not hold my breath.
termleech
Sep 7, 2007
1,154
McPherson, KS
Who knows. It all really depends on how lucky the dev team gets. A lot of the work behind these things is skill and a lot of luck. If you want it quicker, give them a donation and it will persuade them to work on it more. As of last night when I was talking to them they still have no ETA.
kakofonix
Oct 2, 2007
596
I thought "jailbreaking" means the same as "unlocking", which is to free the iPhone of the AT&T lock/hold so you can use it on other networks. Modding (modifying), on the other hand, would mean installing 3rd party applications on any iPhone, jailbroken or on AT&T. If I'm wrong, please educate me.
Arcano
Nov 13, 2007
95
What about the turbo sim thingy?
Alexander
Jun 28, 2007
1,724
Atlanta
"Jailbreaking" breaks the iPhones inaccessibility to Root access open. After you do this, you can install 3rd party applications, or "mod" in other terms. Unlocking pertains to using the iPhone on any network. "Jailbreaking" was available for the iPhone long before unlocking was. An iPhone must be jailbroken before it can be unlocked, but your not necessarily unlocked if you're jailbroken.
