Just received my new iPhone 4 white and the battery is garbage
Jacksworld
Jun 21, 2010
62
I didn't listen to music or watch video I haven't called or received any calls all I did from the time it was fully charged 6 hours ago was read some news off CNN app and fox app I browsed the Internet for about 20 mins and played 3 boards of angry birds I have Bluetooth off and brightness down to half and ping is set to off and I'm at 26% battery life wtf is this normal?
dturner
Dec 15, 2007
5,725
Louisville, Ky.
How much usage time is it showing for that 26%?
one_crazy_dude
Sep 13, 2009
460
72
Toms River New Jersey
Go into settings then mail and see if push is on. It is a huge battery drain and I know keep it off and my phone will last all day messing with it most of the day. Hope this helps
Iloveiphones
Aug 5, 2010
6,237
234
chatsocially.com
Because it's new the battery might need a little stirring up of electrons. Let it go from 100% to 0%. If that doesn't work play with it for a few days and if it still isn't up to par with expectations (about 6.5 hours) then return it.
Jacksworld
Jun 21, 2010
62
I let it go down to like 10% I have brightness down to around 40% I so far started at 9 I checked a few emails read some news on engadget tracked a package with ups app looked online for about 10 mins maybe less played 3 levels of angry birds I know it sounds like a lot but on reality I haven't played any videos or music so from 9 am now it's 12:20 and I have 61% battery life so am I ok or should I be freaking out
Syamil
Jan 31, 2011
296
Singapore
From my personal opinion, the iPhone battery sucks as compared to my older phones. I upgraded from a Motorola Backflip to the iPhone 4, and I was quite freaked out at first upon learning that the iPhone drains battery quite fast. Maybe it's your previous phone charging behavior that's making your freak out?
IloveiPhones theory is also correct, though I wouldn't say 'stirring' is. :p
Average iPhone usage is up to 8 hours as according to the iPhone usage counter.
Iloveiphones
Aug 5, 2010
6,237
234
chatsocially.com
Start charging your iPhone as soon as you read this. Let it go up to 100%. then let it get down to 3%. Then go to settings>General>Usage. Then check to see how much usage and stand-by there has been. Then report here. Try to make note of anything you do and for how long. But it's not needed. It's hard to tell right now if it's rotten.
chazm
May 1, 2008
729
40
What's the usage at? A few people have already asked you but you're just letting us know what you've been playing and reading. Who cares? What matters is how long the screen has been on, or in use. Also, compare usage to standby. I have Usage of 3hrs 8 min and standby of 17hours 10 min and still have 51% left. I know a couple of times my usage and standby are exactly the same and my phone is about dead. I do a respring and its all good.
Don't worry about "electrons" and letting your phone die completely and recharge, thats horse poop
Tinman
4,334
183
Aridzona
No it's not. While the phrase may not have been worded to people's liking it was GOOD advice. Even Apple recommends doing a complete charge cycle once per month. Letting it go to zero helps calibrate the metering. Sometimes the battery isn't really dead, the iPhone is just being too conservative with the amount remaining and a complete charge cycle and reboot while connected to power can calibrate it properly.
That said you shouldn't make a frequent habit of letting the battery drain to zero. Lithium based batteries do better with topping off.
Michael
chazm
May 1, 2008
729
40
Michael
If this were true, wouldn't it be noted on the packaging or instructions when you buy the phone? I have never seen this. Don't tell me a Apple store member told you this
dturner
Dec 15, 2007
5,725
Louisville, Ky.
From Apples website:
You can also recharge a lithium-ion polymer battery whenever convenient, without the full charge or discharge cycle necessary to keep nickel-based batteries at peak performance.
http://www.apple.com/batteries/
Sent from my iPad using iCafe app
Tinman
4,334
183
Aridzona
yes that is what happened. An Apple store "member" told me. Sure.
From Apple:
For proper maintenance of a lithium-based battery, it’s important to keep the electrons in it moving occasionally. Be sure to go through at least one charge cycle per month (charging the battery to 100% and then completely running it down).
http://www.apple.com/batteries/maximizing-performance/
Let's see... the guy said "stir" the electrons and to run it through a cycle. Looks like Apple said essentially the same thing.
Michael
radtechy
Jul 20, 2011
505
41
Average iPhone usage is up to 8 hours as according to the iPhone usage counter.[/quote]
When you say 8 hours; you mean 8 hours of actual on time?
So with the phone being on standby that means you can easily get 12-15 hours of the day as long as you aren't on it constantly?
