Just updated to 1.1.3 and...
KTORRES1120
Dec 28, 2007
53
...I still have my own Carrier icon that I created through MIM. Does this mean I didn't upgrade properly? My carrier icon said KT&T on my JB OTB 1.1.2 then after going to 1.1.3 I thought all that stuff would be gone and everything would start fresh? But my carrier icon still shows as KT&T. I only did the upgrade to 1.1.3 because I've been having problems with SMS messages not coming through or being really delayed for the last few weeks and I wanted to start fresh.
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
You should Restore, not update, if you want to start fresh. Can't recall the thread or find it immediately, but this was a quote from Tinman on this subject just recently:
"Also a Restore wipes both the system and media partitions on the iPhone. An Update Only wipes the system, leaving the media Partition alone (so you won't need to reload music, etc.). Many third-party apps store data on the media partition so if you update rather than restore that data will remain (e.g., Installer files).
So the very best way to clean the iPhone is to do a full restore, and then don't agree to use the last backup (which means nothing on the iPhone will be saved).
KTORRES1120
Dec 28, 2007
53
Hmm, does that mean I will lose all my SMS messages, Address books, music, photos and videos? Or does iTunes store this info to later be put back on the phone?
The Apple
3,105
Indiana
As long as you don't have any problems you should be O.K. If you start to experience any problems you will probably have to restore your software to its original state and select the option to not use previous backups.
The Apple
3,105
Indiana
So the very best way to clean the iPhone is to do a full restore, and then don't agree to use the last backup (which means nothing on the iPhone will be saved). "
http://forums.everythingicafe.com/threads/to-jailbreak-or-not-to.18750/
The Apple
3,105
Indiana
In order to completely restore the software to its original state, you will have to lose this information. These are the brakes of modifications.:(
KTORRES1120
Dec 28, 2007
53
I will even lose all the info I have on iTunes? Like everything in my Music and Video library? Sorry, I just want to be sure before doing this. Thanks for everyone's help!
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
If your contact addresses exist on your PC/Mac, you should be able to sync them back once you've restored, Same for photos, music, videos - *if* they are on your PC, not solely on your iPhone, then setup sync once restored to sync them across. SMS messages are not natively synced or backed up via iTunes - I think there is a Mac application that will do this for you (can't recall name, Google for it), don't recall seeing anything for PCs and SMS backup ...
KTORRES1120
Dec 28, 2007
53
Ok great Thanks! I just need to start fresh to see if everything functions properly. Then I'll wait a bit until I know the 1.1.3 JB works and back to JB I go!
KNK
Jul 22, 2007
2,391
Stevenson Ranch
I see you are 1.1.2 OBT just to let you know if you go to 1.1.3 and anything fails, you will be staying at 1.1.3 because you can not downgrade from there.:eek:
KTORRES1120
Dec 28, 2007
53
Uh....does that mean that the newest 1.1.3 jailbreak wont work for me?
KTORRES1120
Dec 28, 2007
53
Oh ok cool. Thanks. Well, I'm all restored to 1.1.3 but my SMS texts are still messed up. Thanks anyway for all your help.
