Keep default battery icon as lock/unlock screen
Nov 20, 2007
Does anyone know if there is any way to keep the battery icon as the lock screen when disconnected from the computer? Thanks
Stevonw
Sep 14, 2007
560
UK
It is not possible to do this.
Sorry :(
firewire
Nov 4, 2007
941
17
Sorry :(
Why can't he save the .png file that is for the battery charge as the lockbackground.jpg file? Unless he wants to keep the realtime battery status as the lock screen, not just an image of it, then yes you can't do that.
Stevonw
Sep 14, 2007
560
UK
Yeah, i think he's after a real time battery on the lock screen. Good to point that out though Firewire :D ;).
beezink
Nov 13, 2007
oh man that would be cool.. would it be possible to create a program that mimics that?
rumpelgeist
Jun 20, 2007
165
I would imagine he wants the real battery status, not just an image, as you mentioned.
Rumpelgeist
Nov 20, 2007
Yes, I would like to have had the realtime battery status and not just the image. I see it's not possible. Thanks for the reply guys :)
manimanus
Jul 24, 2008
hiya
hi you can install Itoday that will display weather calendar battery ect.. you chose what u want to display on your locksreen.
can get it on iappcat.com creat account chose apps you want install the repo they give you and you'll have a new package folder with the name you've chosen and the apps inside.
:cool:
