Keep getting code error 3194
lowram00
Feb 11, 2008
468
memphis TN
im running 4.0.1 and its jailbroken and im trying restore with 4.0.1 but keep getting error 3194 anyone know why and how i get it to restore with 4.0.1
lowram00
Feb 11, 2008
468
memphis TN
naw the phone not in recovery mode just at the normal running i just hit restore and shift pick 4.0.1 then after min get error code
Casebrius
Aug 18, 2009
118
Lafayette, La
I have an iPhone 4 running 4.2.1 and have saved SHSH blobs from when I had 4.1 using TU. I am trying to downgrade to 4.1 so I can jailbreak. I have Umbrella pointed at directory with SHSH from 4.1 and started the TSS server.
When I try to downgrade, iTunes extracts 4.1 software, then tries to verify with iTunes and kicks me out with error 3194.
iTunes v. 10.1.1.4
How do I resolve this?
28,365
5,506
Make sure you are using the latest version of TinyUmbrella and put the iPhone in DFU mode prior to the restore. If you still get 3xxx errors, edit your Hosts file so it points to Saurik's server and then shift+restore.
Casebrius
Aug 18, 2009
118
Lafayette, La
Sorry I'm a no0b, how do I do that?
note: my SHSH from 4.1 were never stored on saurick's server because I never jailbroke while on 4.1.
my hosts file looks like this:
127.0.0.1 localhost
#74.208.10.249 gs.apple.com
#127.0.0.1 gs.apple.com
Casebrius
Aug 18, 2009
118
Lafayette, La
OK, I have done all that was suggested. The only address in my hosts file is : 74.208.10.249 gs.apple.com
It still kicks me out with error 3194.
28,365
5,506
If you used TinyUmbrella to back up 4.1, it should have stored the SHSH in Cydia as well as your computer. Does it list your 4.1 SHSH at the top of the Cydia homepage?
Remove the # sign before Saurik's server address and try again.
Casebrius
Aug 18, 2009
118
Lafayette, La
There is no # sign in front of saurik's server now.
I don't think I had an internet connection when I stored my SHSH with Tiny Umbrella, so I don't think they are on Saurik's server.
I don't understand what you mean "Does it list your 4.1 SHSH at the top of the Cydia homepage?" -I am not jailbroken right now.
28,365
5,506
Okay, if you don't have it stored in Cydia, edit your Hosts file so it looks like this and try using TinyUmbrella again:
This is what I was referring to:
28,365
5,506
What OS? I would suggest using another computer, especially if you are using 64 bit Windows, but you don't have 4.1 stored in Cydia, so you need to use your computer as the server and TinyUmbrella. You could probably copy and move your SHSH to another computer.
You have the latest version of TinyUmbrella and you're putting the phone in DFU mode first, right?
Casebrius
Aug 18, 2009
118
Lafayette, La
XP, no other computer options. Yes, latest TU version and putting in DFU. How can I get my SHSH added to Saurik's server?
Casebrius
Aug 18, 2009
118
Lafayette, La
I think I've figured out my problem. When I first got my iPhone 4, I could not get the VVM working and I swapped it for a new phone. I thought for sure these SHSH were from the most recent phone, but now I'm having my doubts since this is not working.
Aug 13, 2011
I'm getting an error everytime I want to update or restore to the current firmware I'm on (4.3.4). I have done google searches and have done the Tiny Umbrella stuff but I still get the error code 3194. I have jailbreaked my iPhone 4 and decided not to have it anymore... doesn't make sense? lol. Please help me update :S
Michael Baturin
Jul 11, 2007
1,745
239
32
South Jersey
I believe this happens because of a non-up-to-date version of iTunes. Make sure the version of iTunes you are using is the version needed to install 4.3.4 which I believe is version 10.4 (current public release)
28,365
5,506
You just need to fix your hosts file so it points to Apple, not Cydia. You can open your hosts file and removed Cydia's Server address or you can install TinyUmbrella and uncheck the 'set hosts to Cydia on exit' box.
Here are more detailed directions.
Aug 13, 2011
@Citsur86 My iTunes is version 10.4.0.80.
@Europa I've done that. Still gives me the 3194 error =\
28,365
5,506
Which method did you use? If you used the second method, did you click Apply Changes and reboot after unchecking the Set Hosts to Cydia on Exit box?
