keep getting iTunes 1013 error when restoring to original firmware
bydus
Oct 10, 2011
Ok so I would like to restore my iPhone 4.2.1 with redsn0w to original settings and after putting it to PWNED DFU state with redsn0w, running tiny umbrella and having edited hosts (deleted them) I keep getting 1013 error.
by now i figured out that 3194 is cause of the hosts, 1600 is bacuse its no't in pwned DFU and while it seems that the restore is almost finished I get that 1013 error and goes back to restore in iTunes. Any way to fix that ?
thanks in advance
fijiman
Feb 13, 2011
832
64
UK
The fact that you're restoring back to 4.2.1 and getting 1013 error means you were successful..... by running Greenpois0n you will not only jailbreak your iPhone but fix the 1013 error.....you need to follow the on screen instructions disregarding the fact you cannot switch off your iPhone..
You just need to kick it out of Recovery Mode with after the restore. Use Exit Recovery (in Tiny Umbrella), Fix Recovery or RecBoot.
