Keep getting message: The software required for the iPhone is not installed?
301finest
Jun 27, 2007
19
don't Know what to do, Anyone with past experiences please help. I cant sync or anything. It keeps tell me to reinstall iTunes But once i do the same message comes up
DRabbit
Jul 2, 2007
383
Are you by chance using Windows 64 bit version?
Sleeper
Jul 21, 2007
256
Have you checked for viruses or malicious software? It may be stuff on your PC that's causing the problem, not the iPhone.
What about Apple's on-line help? Maybe there are drivers you need to download?
301finest
Jun 27, 2007
19
I tried the firewall and cant figure out what it is. I also reinstalled the iTunes software and still no go
Michael Baturin
Jul 11, 2007
1,751
244
33
South Jersey
Solution.
you need to make sure file called iTunesMobileDevice.dll is in this folder
C:\Program Files\Common Files\Apple\Mobile Device Support\bin
during your steps to mod you probably moved this file instead of copy and pasting it. Just search your computer for iTunesMobileDevice.dll (or navigate to the folder on your computer where it is located), copy it, then paste it in the above directory and you should be good to go. (I initially made this same mistake and got this same error).
