Keyboard and Trackpad
Radis
Jul 3, 2007
173
So i turned on my macbook this morning, I am pretty sure it has the lastest version of lepeord on it, and my keyboard or my trackpad did not work.
So i started up in windows and everything worked fine. does anyone know a fix?
I did a little bit of research but i really didn't have any good answers except this one, from
1: turn off your MacBook
2: Insert the "disk 1" OS X disk
3: turn on your MacBook while holding Alt
4: keep holding alt until you reach the boot menu.
5: Select the disk and pick you langauge
6: then continue with the process
didn't know if anyone could confirm that this worked.
I also tried holding command and "S" while start up and then typing in
fsck -y but i was not able to type fsck -y because it did not recognize the keyboard.
Thanks,
Radis
styfle
Mar 31, 2008
3,381
I don't know much about macs but when my keyboard and mouse would stop working on my PC, it was usually related to the drivers. I would take your macbook into the Apple store and have someone look at it.
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
That's odd. Do you have an external mouse or keyboard to try?
